That hurt !
Thanks for the explanation of how you did it, When you say you used a homemade straight edge and dovetail measuring device, what were they like, and how did you make them? Were you using a tube of Prussian Blue for marking.
I admire you persistence.
Downwindtracke
Thanks for the kind comment.
My straight edge was machined and scraped from a piece of 1" x 2" x 26"long durabar.
Here's a pic of the setup to machine the 60deg angle.
This was done before scraping in the mill/drill and a lot of material had to be scraped to get it even close.
This next pic shows some scraping. The lightening holes can be seen.
Prussian blue was used but I've since started using Canode.
Still haven't made the dovetail measuring tool.
I'ts simply a holder that will seat into the dovetail on one side and allow a indicator to read to the opposing dovetail.
Check out some yutube vidios, measuring dovetails or scraping dovetails.
I can see how difficult it would be not having a true surface. You have to measure to something. Durabar is lively, eh. For measuring the dovetail wear, I'm lucky, I found a 6-12" Lufkin on Seattle CL . I guess it was quite a challenge for the old fellow to box it and mail it. There is a time when simple things get to be difficult. When I use it, I'll say a thank you.
