The golden walnut tree.
Scruffy
Jun 5, 2013
549
This whole mess, that I have peed off my wife’s 2 sister’s started about 3 months ago. My wife has 3 sisters, between 55 and 70 .
The one that mows my father in laws grass decided the walnut tree in his back yard needed to go because it was messy.
Now listen my father in law is 99 years old and still lives by his self. That’s right 99 !,
I do some wood working and felled quite a bit of timber . This tree is 32 in. Diameter 1 ft above the ground. Was asked what I would pay for it and I said 200.00 oh boy I was accused of being a thief and every thing else under the sun.
After 10 calls to lumber buyers the best the could eas 500.00 . That’s pay them 500.00 to take it down and clean up and leave the the stump.
Thanks ron
This hits home for me in that I don't understand what's happened to tree prices.
Some 30 years ago, a lumber company offered my wife's grandfather $500 for a black walnut tree. Turned out bad for them since it was hallow when they cut it down.
While I understand there's some risk with purchasing trees, what they offer now is an insult. I had a tree buyer come and look at some large, straight black walnuts I have on my place. He offered $50/tree for 10 trees.
I know these places take hardwoods like walnut and cut them into veneer rolls that sell for many thousands of dollars, yet they only want to pay peanuts. Just take a look at the price of walnut or cherry wood the next time you're at the lumber store.
I even offered to allow them to not pay for any trees that were bad and the best he offered was $75/tree. These were trees 32" plus in diameter and straight as an arrow for 25 plus feet.
For that price, I'd rather leave them to grow where they're at or cut them myself and hire in a portable sawmill for the lumber.
We don't have much for black walnut around here, only the odd tree on an old estate maybe. Can't beat it for colour sometimes though, especially if you can air dry it instead of sending to a kiln. Much nicer. This is from a tree I got wind of about thirty years ago, made a few really nice bowls from it.
-frank
I am a wood worker as well, I too have felled my share of timber, and I chainsaw mill my own lumber for my own use. it is very labor intensive. Then it has to be moved to the side as you mill it, then moved again to load into my truck to bring it home, then moved again to get it into the drying shed, then it has to be stickered and stacked for drying it is very labor intensive. Then I air dry the lumber for a year or more depending on the thickness that I milled it. And that just to get the lumber from the logs to the shed. Do you have any idea how heavy a 2" thick 3' wide 8' long soaking wet board is? Cutting the tree down and cleaning up the debris is another story in itself. and with urban lumber you have to plan on hitting nails and taking time to resharpen your chains. milling with a chainsaw mill itself is very physically demanding, and the equipment is very expensive to purchase and then there is the maintenance, parts, and fuel for the saws. The cost are even higher for a guy with a portable bandmill. Milling lumber for my own use and for my hobby is fun and a great way for me to acquire wood for my own personal use, but it would be damn near impossible to make any money at it with a chainsaw mill, and it would take a lot of logs just to break even with a bandmill. With a chainsaw mill I can mill a log where it falls and carry it away a board at a time, with a bandmill you have to get the 5,000lb or 10,000lb log to the mill to saw it. People never really understand the cost and labor that is involved in milling wood to make a marketable product and get it to market, let alone to use it. Sheesh!........I'm glad its just a hobby for me. That's my old chainsaw mill in my avatar with a couple of smaller boards I milled. The sawmill has a new $1,200 powerhead on it now because milling killed the old powerhead, just flat out wore it out!
I NEVER PAY FOR LOGS!!!!
I try to use reverse economics when I run my home made bandsaw mill. After I've got the free logs home, which involved hooking up the hay wagon to the tractor, driving half an hour to the site (more than a half hour forget it), loading the logs with the forks, the half hour drive back, unloading the logs, and putting the tractor and wagon away, I still have the hard work ahead. Then its get the first log on the mill without breaking the mill or the tractor. Take a cut or two, then if its a big log take the log off the mill and roll it on the forks cause it's too heavy and awkward to roll on the mill. Then put it back and square it up, couple of cuts and repeat till I have a square cant. Then its easy sawing, unless of course I hit a nail, or two or three. Then edge the slabs. After that its sticker it in a shed.
Of course you can't give the slabs away so I haul them to the dump, once or twice a year you shovel out a trailer or two of sawdust that gets hauled to the dump
But then I can say wow sawed 500 feet of pine, some select some common grade probably would have to pay $500 for that.
Problem is I may or may not need that lumber in a year or two when its dry.
Thankfully I don't pay union wages to a crew, don't pay insurance, do my own maintenance, just have fuel oil and parts expenses and ignore the capital cost of the machinery I'm wearing out.
Get a mill and make a fortune.
BUT there is a great feeling of satisfaction when I give a customer a piece of furniture I made from a free log.
Greg
We had limited foresting done on our 64-acres about 10 years ago. Idea was more conservation than clear-cutting. Our guy worked for the State of Michigan and used a rule of thumb of 10-12 18" diameter trees per acre. We had over 20 in some areas so the big trees were competing for the same light. Ours were primarily hard maples, a few black walnuts; had just over a 100 trees taken at about $300 per tree.
We're in "maintenance" mode at this point. Plan is to take 10% of the trees every 10 years so the entire woods turns over every 100 years. Just had a guy quote us the same $300 per tree for the maples and walnuts, so timber prices are holding in mid-Michigan.
Bruce
I say let the complainers do the calling and see what kind of deal they can get. Then you have the right to match the price, at your discretion. Can't be any more fair than that.
I agree with what others have said. People don't seem to value the time, effort, risk and cost involved in turning trees to lumber. Years ago when we first moved to the country, I bought a little bandsaw mill and was super excited to cut down trees and turn it into lumber for wood working projects or building supplies for my own use. One of our new neighbors stopped by and seen the mill. His eyes lit up and asked if I would cut him some 1" x 6" trim boards for his house. Wanting to be a good neighbor I said sure if he brought me the trees. He brought over some dead trees that were cracked, some to the core, and the cracks ran radially along the length of the trees. Some of the trees were only 6" diameter too. I milled it all up for him but there were a lot of boards that came out cracked and were simply a waste of time to produce. I ended up giving him 100 8' 1" x 6" boards and 2" x stock from what was left over.
He later complained that some of the boards I cut had shrunk. A few days later I'm still thinking about the nerve of this guy complaining about the free work I did for him and he shows up at my place with a trailer load of logs and tells me he wants some 2" x 4" and 2" x 6" boards cut from these and he needs them right away. The nerve of some people!!! I am in the middle of building my house (like him) and he wants me to drop what I'm doing and cut him these boards. I told him I was too busy and it would have to wait. About a week later I took a day out of my house build and cut him a bunch of 2" x material, using 1/2 of the logs he brought over and I decided his payment for my work would be for me to use the other 1/2 of the logs for myself. After that he went elsewhere and paid for someone to mill his lumber. Now he complains to me about the lumber he gets milled elsewhere.
