[4]
The last I saw of that spring
[3]
[10] Like what you see?
HourhandSam
Newbie
Oct 8, 2014
13
Greetings, I have a movement in the shop (Urgos) that uses a compression spring on the main wheel. While attempting to remove the actuating cam on the front side of the plate the brass retainer slipped off of the bottom of the wheel and the last I saw of the compression spring was out of the corner of my eye as it flew thru the air with the greatest of ease. I've looked for that spring for 2 days now and have decided I need to stop wasting my time and solve the problem. The spring in question was approx .375 X .375. Does anyone have an idea on how to make this spring or replace it with something that will do the trick. I have no junk Urgos movements to steal from so I need some ideas. Thanks for your help. Cheers Sam
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,605
Maybe your local Ace Hardware? My local store has a pretty good spring assortment.
Dave Smith
Mar 10, 2013
1,088
Sam---do a rough drawing of the measurements of the spring and the wire size---and I can find and send you one----I have thousands of springs and very good assortments---Dave
D
Deleted member 17524
Guest - Please Register!
We have that problem taking the small c type springs out of the pistons to get the wrist pin out of model airplane engines. If you can find one capable of holding your movement us a plastic bag. Put the movement inside and anything that flies off stays in the bag. I get my bags at the local dry cleaners. They are crystal clear. Just a thought for next time.
"Billy G"
HourhandSam
Newbie
Oct 8, 2014
13
If only I were that lucky, I had to explain the difference between extension and compression springs to the manager. Cheers Sam
HourhandSam
Newbie
Oct 8, 2014
13
"Billy G"
Thanks Bill, I wish I had thought of that before I tried to remove the cam. I WILL use that idea in the future. Cheers Sam
HourhandSam
Newbie
Oct 8, 2014
13
Dave, thanks for the offer. I'll take some pictures and measurements and get back to you. If I try and draw something it will be unrecognizable. Cheers Sam
Dave Smith
Mar 10, 2013
1,088
Sam---if you can just give the od --the approx expanded length and the approx needed compressed measurement.---for instance I have one 3/8" od x.45 expanded length x .082 compressed length and the wire size is .011-------I dropped it three times measuring it but found it each time----I use a magnet and can find them stuck to it after scanning the floor in a sweeping motion----anyway try and guess some measurements that are close--unless you have the actual specs-----------Dave
silence dogood
Jul 10, 2013
410
Sam, I got one of those magnets that has a three foot handle that when you pull on the lever, it will release the metal. Not always but I have found many a screw, nut, whatever that way. That magnet sure is handy. Mark
mikey
Dec 20, 2012
5,143
I use an old speaker magnet fixed onto the end of an old broomstick. It seems the older I get and the smaller the part, the more useful that magnet becomes.
I dropped all 25 bearings from an Albrecht chuck on my garage floor, not once but 4 separate times! Found every single one of those little buggers with that magnet and if you saw my garage you would know what a miracle that was.
Ebel440
May 24, 2014
550
You can get piano wire at hobby stores then use a screw with the right diameter and pitch to wind a new one drill a hole through the screw to hold the wire then wind the wire into the threads. It will spring open some so it may take a few try's to get the right size.
HourhandSam
Newbie
Oct 8, 2014
13
Dave, I've done some measurements and can give you the following:
arbor diameter.079-- so I'll need something with a larger diameter. My original post of .375 was way off of the mark.
approx OD .158, that's the OD of the disk that retains one end of the spring. If you can't find anything that small I can always make a larger retaining disk, within limits. The clock is pretty crowded right there.
length: .5 inches max, .4 inches min. .4 puts me to the end of the arbor and then I have to add the thickness of the retainer and brass bushing that holds the spring in place so that will give me compression, hopefully not too much or too little, just like the 3 bears.
wire gauge: approx 72, most likely anything with a diameter of .020-.025 will do nicely.
I have worn out both of my shoulders swinging my magnet attempting to find that darn thing. My shop has too many nooks and crannies and I'm sure I'll come across it sometime in the future. In the mean time I've now ruined a pair of pants at the knees from crawling around on cement. Oh well, they were almost as old as I am. Cheeahs(That's with a Maine accent)
HourhandSam
Newbie
Oct 8, 2014
13
Try McMaster Carr http://www.mcmaster.com they have a huge spring selection.
You're not wrong there. If Dave can't find something for me I'll give them a close look. If I can't find something there I'd be very surprised. For some reason I never think of them. I will no longer deal with Enco and have moved to dealing with the smaller vendors for my machining needs. The smaller vendors don't carry those little items like fasteners, springs, etc. I'll have to rethink my buying habits. Thanks for the heads up. Cheers
HourhandSam
Newbie
Oct 8, 2014
13
Great thought! I'd have to get the piano wire on line as the only hobby store around is Hobby Lobby and they have everything the ladies require for their crafts but so far I've found nothing that will help me. I've been surprised not to be able to find hobby shops in north central Maine. You'd think they'd be popular due to the long winter but snowmobiles, hockey, ice fishing, skiing and drinking occupy a lot of the male population. Cheers
David S
Nov 18, 2012
1,320
I repair clocks and when I need to make steel springs I use music wire from my local music shop. I just go through their assortment of guitar strings. A single string here is around $1.25.
David
Ebel440
May 24, 2014
550
It seems hobby shops are becoming endangered there used to be a few I used by me and there's only one left. Possibly the internets killing them off. You can also use single strand stainless steel fishing leader material. That may be harder to find though.
Dave Smith
Mar 10, 2013
1,088
Sam---PM me your address and Ill send some small springs that should work ok---a few sizes.---you can always cut if you find one that is too long----Dave----- **I can get them in the mail tonight if I get your address soon
HourhandSam
Newbie
Oct 8, 2014
13
David
David, another great idea, if I combine this one with EBEL's idea of the hole thru the screw I could probably make one that fit exactly. Thanks for the idea. Cheers
HourhandSam
Newbie
Oct 8, 2014
13
Thanks, another good idea. I'll check it out the next time I'm in a tackle shop, I'll look in Dick's too as now that I think about it I don't know of any tackle shops around here. I'm about 1 1/2 hours from the coast, but maybe ss fishing leader is used with Ice fishing gear. I have to urinate too often to Ice Fish, I'd spend all day walking back and forth to the woods. Cheers
HourhandSam
Newbie
Oct 8, 2014
13
sounds like my shop, I spent hours doing that before I jumped on the forum. This time the mighty Casey has struck out.
[6]
[5] [7]
