H
Hukshawn
Forum Guest
Register Today
My Delta drum sander. I got it from a highschool several years ago. The drum is dented. One significant dent, and a few other minor ones. It doesn't cause issues, just noisy as the dent goes around hammering the work piece. I mainly use this sander for cleaning and leveling, and finish sanding is done on the stroke sander. So, finish isn't the issue, it's noisy and I don't like that it's dented.
I've always thought about pulling the drum out and skimming a layer off on the lathe. The dent is about .011" deep, however, the wall thickness of the drum is only .100". That's not a lot of meat...
The dent is between gussets, but I have way of pushing the dent out, I considered riveting and a dent puller, but the .100" is likely too thick for that.
I have aluminum arc welding sticks, but that would likely destroy everything.
Maybe brazing? Can you braze aluminum?
Looking for suggestions. And if that doesn't work, the dent will remain and I will move on in life.
You can see the void in build up where the dent is here.
And the thin wall. There is a web structure with a center hole for a shaft, so, making a new drum would likely not be possible as I'm sure this drum material was extruded for this purpose.
Delta does not support parts in Canada anymore. Parts for this sander are not available, so I've been told.
