Thinking of making a change to my mini-lathe
Billh50
RIP 2018
Rest In Peace
Jan 26, 2015
1,939
I have run into a time or two where I need a slightly longer lathe than my Homier 7 x 12. I was thinking of taking what little extra I have at end of next month to buy the 16" bed kit from LMS. I figure it would be cheaper than trying to find another lathe that I can't really afford. Need a steady rest also. But might have to wait til end of December for that.
Has anyone done the 16" swap? If so, was it worth it?
I know it will mean putting off buying a mill til next year, as long as nothing else goes wrong by then. But I wouldn't have enough for a cheap mill til next spring anyway.
Why not try buying just an extra bed from grizzly or HF . EBay may have something too.
The kit contains a bed, a chip tray, longer rack , and longer feed screw for not much more than the cost of just a bed.
Roy has done that upgrade you're talking about and he sounds very impressed with it, I upgraded with the LMS cross slide travel extend kit and it was the best upgrade I could have done to my 7x16 lathe.
Thanks,
I guess I will buy the kit after I get my SS. If I sell a new set of tires I have on craigslist then I can get the kit and steady rest.
Yes Bill I did the 16" kit upgrade. Well worth it. Be carefull when laying out the mounting hole for the change gear adjusting stud. I measured twice and drilled once but it was still not right. I made a bushing and tig welded it to the change gear bajo where I wanted it to fix this. I First bored out the hole in the banjo before welding. It is better than ever now. The extended cross slide kit works excellent with this along with a 4" chuck. The bed kit also includes the new style motor mount which is an order of magnitude nicer than the old mounting. The instructions have a list of taps and drills you will need. If you don't have them I can send you the drill/tap kit I purchased from LMS for bed kit. It actually just duplicated the taps and drills I had.
I'm going in for angiogram and or plasty thursday so I may take a couple of days to send you the drills/taps if you need them.
Roy
I have hundreds of drills and taps. So that won't be a problem. I can't afford any more than the bed kit and maybe the steady rest. Right now even the steady rest may have to wait til after Christmas. I won't be buying the bed kit until after the 3rd anyway. Then I look at all the bills to see what little extra I will have. Just glad the wife does lawn mowing for money to buy groceries or I wouldn't have anything left.
She's a keeper she is.
Bill it sounds as though you have a wonderful wife. I do understand your position as I was in the same not very long ago. I'm 100% disabled by the VA for AO Ischemic heart disease so I get more per month. I will see how it goes with the blocked arteries. If I survive I'll send you the steady rest. Which size do you need, LMS has two, 0-1" or 1-2". What color? Helping out a friend who helps others. God bless.
Roy
either one and any color. I can afford a can of paint. The 2 inch would probably work better. I can always make longer fingers.
Had rough night last night as I started taking on fluids and couldn't breathe. Had to take an extra Lasix last night so I could lay down a couplle hours later after getting rid of almost a quart of fluid. Have to try and get rid of another 3 lbs today. If it isn't the cancer it's either the heart or uncontrolled diabetes. The diabetes they can't do much with because of what the chemo did to the kidneys. But I am not ready to give up yet. I was supoosed to be bed ridden by the time I hit 21 because of my heart. Well I am 67 and still fighting.
I will be here to help as long as I can. It may only be to do research and find stuff for people but I will do what I can.
Bill I am so sorry to hear of your medical issues. You are a fighter. Keep on fighting it.
Roy
