- Feb 1, 2015
- 9,578
For years now, I have been constantly annoyed with intermittent flashlights as the batteries aged. Generally, a good shake or sharp rap would get them working again, only to crap out just as I was performing some critical task. I figured that it was something to do with the construction of the cell; probably the manganese dioxide depolarizer shrinking away from the central nail. Queries to battery manufacturers and on line searches were of no use.
Last week, I noticed that the batteries seemed loose in the flashlight so I pulled them out and measured them, They had shrunk! Well, not really but the cathode button on the end of the battery had become depressed. Unlike the old fashioned zinc carbon batteries which have a central carbon rod which extends through the case and is capped with a steel button, alkaline manganese batteries have .012" steel cap with a central boss which is spot welded to the case. This boss becomes deformed with any significant jarring.
To correct the shorter length I added a small button of solder to the cap. When the flashlight was reassembled, the intermittent lighting was gone. A quick fix to an annoying and persistent problem.
