5/16 wall for a 1/4” bolt/set screw is on the edge. Delvin is pretty tough, but that’s pushing it. If I’m thinking about this right, there’s an inner sleeve you are making. The sleeve fits between the inner tube and an outer tube. The outer tube has a hole in it for the set screw to tighten down on the inner tube - set screw is threaded into the sleeve? Ideas maybe - what would happen if you put two set screws in opposite of each other so you don’t have to tighten them up as much. What about making an outer sleeve, over the top of the tube, with a heavier wall to get more thread engagement, set screw going through the side of the tube and the sleeve so everything stays in place? Or make the sleeve longer with a step that goes inside the tube and a bigger OD for a thicker wall that hangs down a little?
As we are frequently reminded, a picture would be nice. Good for you on trying to fix it instead of just chunking it in the dumpster on the way to the umbrella store.
