To preface, I’ve been threading on a lathe for a few years, without any particular difficulties.
I was attempting to copy the threads on a barrel shank, using the pitch diameter as a reference. When cut to an identical pitch diameter, my threads did not fit the receiver. After reducing the pitch diameter an additional .008”, a good fit was achieved. The threads look perfect, the fit feels great, everything appears to be as it should, except, the pitch diameter.
Things I’ve checked:
Compound at 29.5° (the correct 29.5°), confirmed with bevel protractor.
Tool centered for height.
Tool squared to work.
TPI correct.
Different inserts tried, to same effect (full profile, and simple v)
I realize it is possible that the threads I’m copying are incorrect somehow, but I would like to know what I might be doing wrong.
TPI correct.
