threading dial...
rambin
Jul 29, 2013
237
hey guys my 04tlc-700a wards/logan didn't come with a thread dial for some reason or another. my parts manual says that the 10 and 11 inch both use the part # la-12-2 thread dial... I was wondering if this part is only used on the 10-11 wards lathes or if some of the other logan models dials would work on this lathe and if so what models are compatible? I see some available on ebay and just want to make sure there the right one b4 I plunge into it...as they aint cheap!
could someone with a logan 200 series look at there dial and see if it uses the same part # as mine? (la 12-2) its the closest to the 700 series in size and shape I believe
Could not find my manual, but have a parts book from Logan that says the complete threading dial assembly for the 10 and 11 inch lathes is part number LA-12-2 (listed as "old part number"). LP-1767 is also listed as "part number", current part number, I assume.
I believe there are images of these on the Logan parts site - that may help.
Good luck finding one.
Can you post of picture of your carriage in the area where it mounts?
I'll wander out to the shop, check mine & then check available info.
I believe that the 'barrel style' was used across the board but I can't swear to it.
Here's a close up.
I never did paint it...
Also, I ended up using one of those serrated washers between the body of the dial and the apron. A regular lock washer felt either too tight or too loose. Maybe just my machine though.
yes my parts book for the 700 series says the la-12-2 fits all the 10-11 logans.... what im unsure is that the 10 and 11's in the 700 series (which is wards) or all of them? what model is your manual for??
I took my info out of the parts catalog because I couldn't find my manual. My lathe is a Model 200.
After looking over e-bay, I think you need the Logan model with the "skinny" brass frame with the straight gear teeth that are more exposed, with housing at top dial only going partially around the perimeter of the dial.
They're all a bit pricey. If you can find someone to "print" a plastic gear for you or cut one out of nylon, you can probably make the rest out of some drill rod and a block of aluminum. Might make a nice little project. A bigger dial sure wouldn't hurt.
I hear ya on the bigger dials these logan engineers musta had some awfull good eyes.. look at the crossfeed and compound dials there patheticly small.. heres a pic of my setup the distance (eyeballed) center of crossfeed screw to the mounting screw is 2 and 3/820180123_154036.jpg20180123_154047.jpg
any part number stamps on yours? the 200 is the closest model to mine... im curious if yours is the same as the pics look very close to yours minus the dial ;p
