I don't know if this helps you at all, but here are some pics of mine. These are just some I already had, if you need a photo from a different angle or a measurement, let me know.
wow I didn't realize how much the 700 and 200 resemble each other. apparently they just pulled model numbers out of there hats... no way to really be sure if the dials are the same though without looking at part #'s..... I don't even know if there stamped most parts of my lathe are when I was cleaning and painting on it was usually finding numbers on every part. only things I can think of that can be different on these dials are the length from the attaching bolt to the gear? and maybe the #of teeth on the gear?
Based on T.J.'s photo, it looks like the heavier style is also a direct fit.
I also get about 2-3/8" from bolt mount to center of gear on the Logan 200.
Looks like e-bay has a new listing for one of the heavier style units.
look at this info I came up with on the 200... according to this it does use the same la-12-2 as my 700 calls for... opens up the possibilities on ebay..
