Hi everyone
I am going to try threading for the first time.
Can I cut an external thread without a shoulder?
I am using an Emco Compact 5 mini lathe.
Thank you all in advance,
C
I would still start in a groove. The procedure typically involves setting the new cut depth before engaging the half nuts which will result in a groove anyway. The groove allows a little leeway om positioning the start of the cut. Additionally, if there is any backlash in the drive, that has to be removed before the thread starts.Sure! You can turn the cutting tool upside down, run the lathe in reverse, and thread from Left to Right. This allows you to cut RH threads correctly without a shoulder, as in starting from the head down. If you search around, there are a lot of photos and descriptions for this process.
