[4]
Threading!
[3]
[10] Like what you see?
Shootymacshootface
Active Member
Mar 17, 2018
354
I learned something that will stick with me over the weekend. I made 2 arbors for an old Craftsman dual shaft motor that will br my new buffer. The 1/2-20 threads that I made on the first one came out spectacular. I was very pleased how smooth and perfect the fit was.
Here it is. (The larger one)
15469067950551e673898c9267cf3245a82547111c8cb60b7380219d5db6263995358b9b8a2fe89003b3c0392d832f...jpg
The second one came out rough and several of the cuts I expected only little shavings to come off, but I was getting large chips instead. I finally got the nut to thread on and it will work well enough to hold a buffing wheel.
1547417235397046676403faec66f18777e0fef9e57c4f2f3c7b13cda61f27a1a3fc5651396edb29ba98fb9e500ab2...jpg
It wasn't untill I was almost done when I figured my mistakes. The 1st mistake I made was not freshening up my threading tool. The 2nd and bigger mistake I made was bumping the tailstock into rhe part and pushing it back into the collet.
Just wanted to share what I learned.
Shooty
Shootymacshootface
Active Member
Mar 17, 2018
354
No ,I didn't think of that. Maybe I will replace the not so good one with a left handed model.
Thanks!
Technical Ted
H-M Supporter - Gold Member
Nov 5, 2016
845
Thanks!
I'm glad I mentioned it then. There's a real danger of it unscrewing during use and that wouldn't be a good thing! ;)
And, you'll get some more nice practice threading too!
Ted
[5] [7]
