- Dec 31, 2010
- 937
I am trying to cut 7/8" X 14 TPI in a blind hole in a 1 1/2" aluminum rod. I have cut the external threads on a piece of mystery metal that fit a factory nut closely-can be run on easily. I am using a 4 way tool holder to hold the boring bar that has the cutting tool in the 45` end. I ran the carriage up against a stop on the way and used # 1 only on the thread dial. I did not cut a relief groove as I thought the bit would do that with each pass. The work piece was turned in forward direction with the cutter upside down on the far side of the hole. The carriage ran left to right. When I finally got to size the "bolt" was at an angle. The threads were oversize and when I got the bolt in more squarely it was still out of line.
The things I will do differently on the next try are: 1.Cut a relief groove 2.Chamfer the bolt and the hole 3.Blow the cuttings out after each pass 4. Try putting some lubricant in the hole. Perhaps this post belongs in the goof and blunders dept. but I still don,t understand why the "bolt" would not go in square. Any suggestions will be appreciated.
Ray
Ray
