- Dec 25, 2011
- 10,507
"End Float", usually measured in thousandths of an inch, means axial movement of a shaft of some sort. Probably the most convenient way to measure the spindle end float is to mount a dial indicator to your compound slide or QCTP at an elevation such that you can advance the carriage and bring the rod sticking out of the indicator to bear on the right end of the spindle. Move the carriage out of the way. Tighten either the threaded collar or the nut on the threaded rod until you think that you are close to zero end float. Then bring the indicator to bear on the right end of the spindle and while pushing the spindle toward the tailstock, zero the indicator. Push and hold the spindle away from the tailstock and any movement of the indicator will be the end float. Reduce the end float to zero by whatever method you are using and then tighten the collar 2 teeth of the spindle gear. Then check that the spindle is still free to turn but with a slight drag. This should all be done with all components at room temperature (~70°F). When satisfied with the preload, check and confirm that the brass or lead pellet is still present in the tapped hole(s) in the collar, insert and tighten the set screw(s). And finish reassembling the headstock.
