Hi All,
Removed from lathe and re-set to machine crankshaft shafts, had to reset and glue in the crank spacer. Started with the front shaft, then machined the rear rotor/drum, drilled for crank webs and rough machined.
Machined up a jig to hold the crank and mounted in the mill and finished machining of the crank webs.
Removed the crank spacer and cleaned up the machining marks and edges.
Cheers
Andrew
Cheers
Andrew
