For those of you who have a guick change tool holder system, the Foredom 44T flexable shaft handpiece is an exact fit for the 1 in boring bar tool holder. Gives a quality tool post grinder setup. Jbarnes
Yes, so does the Dremel when mounted to the compound. But I think both the Foredom and Dremel are limited. Do you have a “real” tool post grinder so you can compare? And be careful of the grinding swarf that is created. It can raise havoc on the machines moveable parts…Dave
