- Mar 10, 2012
- 1,368
So I'm starting to do more projects now that require more accurate measuring than I've been doing. I don't do many big >12" parts so I'm considering a 12x18 size plate. I can pick up locally a grade-B Standridge surface plate via McMaster Carr (love that place!). I know I can get much cheaper via Woodcraft or MSC but shipping is killer or the quality might be/is suspect. From what I've read most home shops are using the 12x18 so I think I'd be ok with that size. Any opinions on the size? How are you guys supporting your plate?
As far as measuring I now have: good 123 and few angle blocks, good set of parallels, good hole gauges, good analog and a decent digital micrometers. Should I get a height gauge, combo square set, or something else? I'm leaning towards a height gauge but but figured I'd ask you guys. If height gage what type? Vernier, dial, etc? Thank you.
