Trade 4 jaw chuck for 3 jaw chuck
Olddaddy
Sep 23, 2015
170
I have a pair of Union Mfg 6" 4 jaw chucks that I would like to trade either one for a small, 4" or maybe 5" 3 jaw chuck. One has a backing plate, the other does not. I need to be able to mount a 1.189 ID bushing on the inside jaws. Trade even over, up or down.
I have a 4" 3 jaw chuck with 1 1/2 mount from a Atlas lathe i f you can use it.
Charlie,
I don't have a small chuck to trade to you but if I understand correctly what you need to be able to do, I'd like to suggest an alternative solution. The problem with holding the ID of a bushing with a 4-jaw chuck so that you can machine the OD is that if the bushing doesn't have a pretty heavy wall thickness, tightening the chuck inside of it could distort the bushing at the four points where the jaws are touching. Then you turn the OD down a little bit and everything will look fine until you loosen the 4-jaw enough to rotate the bushing 45 degrees, and re-tighten the chuck. If you then indicate the OD of the bushing you will find that it is not perfectly round.
To avoid that happening, you can use an ID expanding mandrel. At any given time, you will usually find a relatively cheap set of expanding mandrels for sale on eBay. They are of course made in China but if you hold the 1-1/4" diameter one in your 3-jaw chuck, mark where Jaw #1 is in case you need to remove it from the chuck and later reinstall it, and turn the mandrel down with the adjustment screw just snug until you can just slip the bushing over it, and then tighten the mandrel, you will get a part that is not slightly egged and an indicator on the OD should show zero run-out.
Thank you. I will keep that in mind. The problem is this, I have the 8" chuck and I don,t think it is going to work on my Atlas 10" lathe. That is a real heavy chuck. I already have a 4" and a 5" 3 jaw chuck.
Jan the Man
Jan,
OK. You need to start a new thread if you want to find a new home for the 8". That is a little large for a 10" lathe. And maybe the 4" 3-jaw will work for what Charlie was looking for.
I have a 4" 3 jaw chuck That would trade for a 6" 3 jaw chuck.I do not know how the run-out is though. I do not have a way to check it.
