- Jun 12, 2018
- 712
I have a PM25MV mill and I'm trying to tram it using one of these. Tramming the X axis was pretty easy. I'm now within .001, but the problem is the Y axis. I'm off by .025.
There's 4 allen head bolts holding the column. I've done this before and I have to shim the front or back with feeler gauges until I get to within 1 thou.
My question is, will this mess up the "squareness" of the millhead to the table? I don't think it will because the table moves side to side, front to back, and not the column.
If I unscrew the 4 allen bolts, the colum is guaranteed to shift side to side, even if a tiny bit, which will ruin the squareness of the column to the base of the milling machine. Instead of the column facing directly to the front, it will be shifted sideways a bit.
