- Aug 3, 2017
- 2,437
So, I have an Atlas 7B, as some of you may know, that didn't come with a Vise. Shaper vises are stupid-expensive, at ~$350 for one filled with holes.
I built a 2 part vise from (mostly) scraps, which has been... "alright". I get quite a bit of jaw lift on it that even putting a piece of wire in between the jaw and material doesn't fix completely.
SO, I decided to use my extensive tool collection to take this: https://www.ebay.com/itm/3-Milling-...d-With-360-Degree-Swiveling-Base/264266308467
A distinctly vise-shaped-object, that has about the right dimensions. It is a little tall at nearly 3" and I have no idea how the bolt holes will line up. PLUS, the reviews on these seem to be "don't buy this for anything requiring precision unless you have a surface grinder". However, I _DO_ have one, so $60 for a big step ahead in the project seems like a good idea! Plus, I really do like ang-loc type vises.
I plan on modifying this in a few ways.
-I am hoping to get the total height under 2.25" if at all possible, which seems like a doable goal, closer to 2" if at all possible.
-Length wise, it seems a little long. I might find myself removing a bunch of the surrounding casting on the mill in order to make it fit better on the table.
-I'll obviously surface grind it to the best of my ability to get it running flat and true.
-Deburr/desand-for-days. I know these chinesium vises come filled with chinese sand and junk and goo. I'll be removing as much as I can.
-Anything else you guys think would be a good idea!
So far, I've ordered the vise, and thats about it! It should show up in about a week.
