- Oct 2, 2016
- 9
Hello,
I just purchased a Tree 2UVR, it was wired for 440 volt. I need some help in getting it to 220 volt. In the manual there are diagrams for both high and low voltage. The T1, T2, and the T3 connections are currently wired to the forward / reverse switch. One of my questions is do I wire T1 & T7 and so forth to the switch and tie the T4, 5, 6 together? What is the item that has on it 480V 60HZ, AB 70A288? I assume I need to change those out for 220V ones, correct?
Thank you for any help you could provide.
Garrett
Garrett
