I have a practical B- quality vise I would like to true up. When I clean it an measure the vise work bed to the mounting surface at 4 corners the values are off by about 10 thousands. The plan is to mount the vise upside down on V blocks and clamp securely to the mill; and then carefully taking very light cuts mill the mounting surface.
Will this work? Is it a fools errand? I have a need for a reasonably accurate vise of this size and the quotes are in the $200 range. If I can improve this vise it will serve well.
