Thought you might like this. The man is cutting off the axle spindle and welding on a new one. This is done when the bearing spins too bad on the spindle. He cuts off the old spindle, bores out the axle housing. He then heats the axle housing and press fits the new spindle. He finishes off the job by welding. I had this done about 30 years ago to a Brockway with Rockwell axles. The driver started to haul out a load of logs when the rear wheel was sticking out more then before. When I pulled the wheel, the spindle had been ground down. I called a company and they did this repair in the woods. I don't remember the cost then, but this guy said the repair is well North of $1K. I was around the Brockway for over 8 years and there was never any problems with the repair. This is cheaper then replacing an axle if you can get one.
The repair is done by a certified welder and the repair is DOT approved.
