• PHISHING SCAM attempt TARGETING HOBBY-MACHINIST members. It has been brought to our attention that a pop-up survey is soliciting userfeedback from H-M members. In exchange for survey information, the user is given an opportunity to win a prize if they pay for shipping charges. This is NOT a Hobby Machinist program, survey or contest. DO NOT click through the links. Close your browser immediately and restart your computer. Clear cookies, cache and log back into Hobby Machinist. Again, this is NOT a Hobby Machinist contest or survey - IT IS a PHISHING SCAM attempt to get your credit card information.To close this notification, click the "X" in the top right corner of this box.
Trying to read a motor plate on an older GE 5k49- motor
silverforgestudio
H-M Platinum Supporter
Jul 8, 2015
129
Hope this Monday is finding all safe, well and in good spirits! I had to come to work to get a day off from the housework from the weekend!
Got a Boyer-Schultz 6x18 and its got a beautiful old GE 3ph motor on board... no worries- Ill get a VFD for it.... The plate is wiped clean except for the stamped in data- and I certainly am no expert of how to read one.
So I thought I would bend the ear of the collective group of chaps (and the 'lassies if they are about) to get a bit of an education if I could.
Pics to follow and my assumptions about this plate as well...
FOMOGO
Sep 2, 2013
2,224
Looks like 1/2 hp, 3 ph, amperage @ 208 and 220V, continuous duty, service factor 1.25, rpm @ 50 & 60 HZ respectively. Blow it out, check the bearing condition and should be good to go. Cheers, Mike
silverforgestudio
Jul 8, 2015
129
So I am understanding the plate info correctly- I will go line by line-
Line 1:
5K49-Blah Blah Blah-1655 1/2 HP 3ph
Line 2:
RPM is 2875/3450 volts 208-220 WHAT IS THE 1.6/1.4???
Line 3:
Hz is 50/60 WHAT IS 50/A00?? Continuous Duty
Line 4: (I have no clue what these designations mean)
L 1.25 902 NLF
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
1/2 HP
3 Phase
RPM = 3450 @ 60Hz
Voltage = 208 or 220 (commonally 230V today, I would set the VFD to output 220V)
Amps = 1.4 @ 220V
Service Factor = 1.25 (continuous duty)
silverforgestudio
Jul 8, 2015
129
Hey thanks Mike- Ive got some good ideas from your other content here- Im looking for the "VLA" as I am trying to get a VFD on this guy- and have no experience buying a VFD (everything else is single phase except the KMG which already has a VFD on board
Blew it out- it spins a treat- looking to replace the "OIL CUP" on the rear bearing with an auto-oiler...
silverforgestudio
Jul 8, 2015
129
Hmmm- one concern- This s an older motor- I will not be ramping it up or down in RPM- just on/off- Its a surface grinder so not much need for variable speed there...
Can this old motor "take" a VFD?
FOMOGO
Sep 2, 2013
2,224
For $5 or so, you could just replace your old bearings with sealed units (check e-bay with your old bearing numbers, with a 2RS suffix), and no oiling worries, and maintain the old school look. As Jim explained above, the 1.6/1.4 is the amp draw at 208/220V, higher V = less amperage draw. Mike
JimDawson
Global Moderator
Staff member
Feb 8, 2014
9,654
I think the motor will be fine. I would ramp up over about 5 seconds, and set the VFD to ''Coast to Stop''
jbobb1
Dec 14, 2018
210
That motor has bronze sleeve bearings.
AdBlock Detected
I've Disabled AdBlock
