- Apr 29, 2019
- 2,045
OK it always seems that there is some one that will know something or at least have some good ideas.
Here is my situation. The cable price just took a dramatic price jump and has exceeded my wallet tolerance.
So I got an omnidirectional antenna since I am only about 15 miles from the transmitters.
Overall the antenna works great.
The problem is, the transmitters are all almost due north of me. Directly across the street to the north is a 5 story high brick apartment building. The picture quality is still flawless. Now the fun part. I live very close to an international airport with a lot of airliner traffic. The airliners go by about 2 city blocks to the south of me and are at less than 1000 feet AGL on final for the favorite runway. The planes go by about every 2 - 3 minutes. With each plane that goes by It wipes out my TV picture and sound due to loss of signal. I think that what is happening is that the broadcast signal is bouncing off the side of the airplanes and hitting my antenna out of phase with the broadcast signal so neither one can get through.
I bought and tried a directional antenna and that helped a little. I get the signal interruption for a short time and then it clears when the plane is exactly off the back of the antenna and then goes out again as the plane continues on by.
Would it help to put up a wall of aluminum foil on the back side of the antenna to try to block the reflected signal? DO I need to ground it?
Would I be better off spending the big bucks on a bigger more directional antenna?
Any other ideas form those that understand how radio waves work????
