Filler is 70 ksi tensile, so stronger than CRS. More than adequate for this application, no significant load. You will see the long one being manually reset in this video. The short one is underneath and pushes against the stop to trip the release.Filler rod is pretty malleable wouldn’t think a good material for a pin if taking any type of load? Coat hangers might be stronger??
Similar here . We throw out hundreds of grade 8 bolts out daily . Every die change requires new bolts . Some dies require 80 - 100 1/2"-13s . I saved them for a while and just got tired of it . What do you do with 5000 bolts ?I get long 3/4 NC bolts from an engine rebuilder. Cat 3400-series engines require the head bolts to be replaced every time a head is removed, so they have buckets of them, and I drop about scrap price in the coffee kitty every time I drop in there. I find that I can cut down a 3/4" Cat bolt so fast (even with my Atlas 10" lathe) that it isn't worth dealing with smaller diameter mild steel material.
Cat does not {edit] manufacture their hardware, they provide detailed specifications to vendors who source the hardware for them. I spent 5+ years consulting for Raymark/Universal Friction/FDL-USA, who manufactured a range of items for Cat, including sole-sourced friction disks for D-7 steering clutch packs. Cat required them to include the necessary rivets for rebuild kits and the rivets were purchased from a third party.I have found that Caterpillar makes its bolts from a very nice material. It is as strong, or stronger than Grade 8, and machines like butter! It must be a free-machining steel, threads nicely, and it leaves a beautiful surface finish.
The head bolts are not special. They are the standard Cat bolt for that length. All the Cat high-strength (Gr. 8 equivalent) bolts seem to be made from the same material.Cat does manufacture their hardware, they provide detailed specifications to vendors who source the hardware for them. I spent 5+ years consulting for Raymark/Universal Friction/FDL-USA, who manufactured a range of items for Cat, including sole-sourced friction disks for D-7 steering clutch packs. Cat required them to include the necessary rivets for rebuild kits and the rivets were purchased from a third party.
Cat & Deere fabricate and assemble the frames for their equipment, and build engines and other assemblies from purchased components, just like car manufacturers.
That te 3/4" NC are required to be replaced after one use would be an indication that they are designed to stretch during torquing, so they could be a type of free-machining steel.
