I will have a mini lathe with a collet chuck to hold a 1/2 inch 2 flute end mill. I will also have a vertical slide. I will make a fixture that is 9/16th square on entry and L shaped on exit with space for the cutter to allow me to push the timber through which I will mount on the slide.
This is a one off operation and I will need to process about 25 ft of timber plus some circular pieces. Mabe 30 ft of cutting altogether.
The end mill will be new.
Should this work?
Is there a wood cutting tool that I can hold in the lathe [ 3/8th collet ] that will be much better? I am not too concerned about the finish as the machined side will not be on show.
I realise that whatever cutter I use I will generating a lot of sawdust. I do have a small shop vac and I will rig it up to collect as much sawdust as possible from the cut.
I know if I had a Home Depot on tap I could get a ready made moulding but the local stores in Grenada in the Eastern Caribbean don't stock it. The local Pirates of the Caribbean [ marine store ] can get it in teak but 25 ft will cost 600 $ US. I can get the 9/16th in a fine grain knot free timber which might be ramen. for a small fraction of that.
Should this work?
