I used some gasket sealant on the gas tank and it must be working as no leaks after 24 hours.
Still waiting on the fan blade to come in so I will move on to the electronics box. This box will house the batteries, the ignition module, and the on/off switch.
I started with a solid chunk of aluminum of about the right size.
After milling and trueing all the sides it ended up 2.900 X 2.900 X 1.75 deep and a medium pile of chips.
I then milled out the inside of the box leaving 0.125 thick side walls and the same on the bottom.
A mountain of chips all over the place.
2 hours later and here is the result.
Probably the nicest box I have ever made and it is even the right size for the components.
I still have some holes to make for the ignition wire, the hall sensor, the on/off switch, and the mounting bolts. I was going to mount the box on the side of the block but now I think I will use some spacers to get it away from some of the heat.
Thanks for looking
Ray
