- Feb 2, 2013
- 95
I got my VFD today and ran out to wire it up quick just as a test of the motor and lathe and I didnt have good luck. Can anyone here shed any light on the problem I am having? The VFD is a TECO JNEV-101-H1. The display is saying that I have low voltage. I checked and the incoming volts are 117. The motor barely spins when the belt is set close to the motor speed. When the belt is set farthest away from the motor( or with the belt off) it will spin at a decent clip but it sounds underpowered. The incoming power is wired into L1, L3 and PE(ground). The outgoing wires to the motor are wired to T1, T2, T3, and PE(ground). Thats all I need right? The wires going out to the motor T1, T2,T3 shouldnt matter where they are on the motor right or does it? Thats one thing I didnt worry about is the wires coming off of the motor.. or is there a rhyme or reason to which motor terminals the T1, T2, and T3 wires go to. I'm hoping that is my solution, or I have bigger problems because something isnt right. Also, most (but not all) of my garage outlets are GFCI protected and the GFCI tripped as soon as I turned the VFD on. Is that normal or possibly related to whatever problem I am having? This VFD is being wired to a Clausing 4904 with a 1hp 3 phase Howell electric motor.
Thanks!
Bob
Thanks!
Bob
