[4]
Victor AF150 regulator
[3]
[10] Like what you see?
A
abunai
Guest - Please Register!
Victor AF150.
The diaphragm on my mig regulator popped again.
Repair kit is $40.
Even the spare is popped. I think I forgot to fix it last time.
Don't use it much. I unscrew the "T" everytime when not in use.
Repair again, or just replace i ?????t
Is there a better, longer lasting one?????
How are those "bubble" regulators?????
Cheaper, but do they work as well?????
D
Deleted member 34477
I have been running Victor flow regulators since the mid 80's. I simply turn off the bottle when not in use and never had a single issue that I can recall. If you buy one make sure to confirm the connection fitting will work on the type of gas your running.
This is the one I run: https://store.cyberweld.com/vihrf24refl.html
Victor does offer a less expensive flow meter as well for around $120
Groundhog
H-M Supporter - Gold Member
Jan 20, 2016
989
mistakenly posted a second time - deleted
tried to delete 1 of 2. Instead deleted both - oh well!
Karl_T
H-M Platinum Supporter ($50)
Oct 14, 2014
1,094
I do the same as firestopper, just turn off the bottle. never had a problem in YEARS. After you complete the repair, this should solve any future issue.
A
abunai
I was searching ebay and found lots of bubble type for less than $30.
I think I'll give one a try.
I was taught to screw out the regulator, and empty the gas, after use.
Maybe I was taught wrong.
I've had to rebuild my torch gauges a few times.
Next time I'll try just closing off the bottles.
A
abunai
I got a cheap bubble type of regulator off ebay.
It's made in china.
My hose has the normal flare fitting.
The regulator came with a push on barb.
I tried looking for a coupler so I wouldn't have to cut the hose.
No good. It's metric thread.
Should have expected something like this would come up.
I keep on looking around, but I think I'll end up cutting the hose.
A
abunai
Found an adapter and it's working now.
Something might have been wrong with the old regulator.
I'm getting much better welds now.
danny12
Active Member
Dec 16, 2015
63
Abunai, would you mind sharing where you found that adapter I have one of those regulators that I could put to use.
Thanks Danny
A
abunai
I forgot what the sizes were. It was hard to find. Went to Home Depot, Lowes, ACE and True value. no luck.
Finally found it at Air gas Gaspro.
I'll see if I can find the receipt.
I'll take it off and post a picture of it.
danny12
Active Member
Dec 16, 2015
63
I'd appreciate it, no biggie if you don't. I have put off cutting the hose for a year now. High priority lol
A
abunai
The fitting is actually a coupler. It's threaded on both sides, Different threads.
Couldn't find the invoice, but here are some pictures.
Hope it helps you.
A
abunai
I didn't know it existed either, until I went to Gaspro.
I was looking for an adapter, not a coupler.
Now that I know what will work, Home depot or Lowels might have it.
[6]
[5] [7]
