Vise alignment bar ???
U
umahunter
Forum Guest
Register Today
I'm looking for a thread I can't seem to find maybe I'm using the wrong words. I saw at one time a bar you clamp into your vise that lines up with flats on your mill column to quickly square your vise. i thought there was a video on it but now I can't seem to find pics the thread or video anyone make one or remember what I'm talking about. I'm doing a lil more each day as I recover and figured this is a lightweight project I could tackle thanks for any help :) :)
I think I remember that......distant though.
I'll see if I can find it too.
-brino
I did some searching and didn't find anything either. I do remember the subject though and as I recall the tool looked something like this.
The rods are spaced such that you can clamp the bar in your vise and the rods are exactly, or as close as possible, to the same length. Clamp the bar in your vise and push the rods up against the column then clamp your vise to the table.
As far as construction goes your imagination is the only limitation. Let us know what you come up with and how it works out.
why not have them out further and long enough to go into the table slots to align the vice, just a thought. my vice has the tabs in the bottom and gets the vice pretty close with in a few thousands.
I would not trust that bar for precision work. Many times those flats especially on a Turret mill like a Bridgeport are not square to the table saddle travel. It may be a fast way to get it close, but all the machinists I know, we indicate the top of table first in X&Y (aligning head) and then check the solid side of the vise.
Tightly fitting keys on the vise base that fit snugly in the tee slots will align a vise accurately enough for nearly any work. If the vise has a swivel base, it can easily be indicated to near perfection.
Yes it was like that but had a flat on both ends the concept was you perfectly tram your vise then clamp this into vise and bring up to column and set plates in place then whenever you have to move vise this gets you very close
In this case, anytime you add a component to the alignment process you add more uncertainty. I try to keep it as simple as possible. The less the gadgets and newfangled thing a ma bobs the better. They are all just more uncertainty in accuracy with your final result. It doesn’t take that long for me to indicate a vise in and be done with it and know it’s accurate…Dave
On first look, I thought this looked like a good idea too, but I think I have to agree with Dave here. As I thought about it, I asked myself how wise is it to indicate via this jig, a machined surface on the column which may or may not be square to the table, when in fact all you really want to do is to square up to the table to begin with. I use the more traditional method of simple location keys on the bottom of the vice. However, if for some reason I were compelled to make an alignment jig of this nature, I'd do my locating on the table, not the column. In either case I think you can only hope to get it close and I would still run an indicator across the fixed jaw of the vice as I do now with the keys.
