Vise design. Looking for suggestions, critiques.....
12bolts
Global Moderator
Apr 23, 2011
2,476
Going to make a vise for my (9") shaper, with the likelihood that it will get used on my mill as well.
I have a few odd pieces of mild steel plate that look just the bits I need. But before I start cutting I thought I would see what the rest of the group thinks about my plans and design.
I am going to put the screw thread the full length of the vise and have it supported by bearings at each end, and a removeable bearing cap to facillitate assembly. The fixed jaw will be keyed to the base and secured by cap bolts from underneath. The moving jaw will sit in a slot and travel along the fixed threaded spindle, and have a plate secured to the bottom, running in a recess in the base, to assist in helping to stop the jaw from rising during tightening.
I am thinking about making the base as large as my shaper table, (7" x 11") so that will give me a jaw width of about 5" and a clamping range of about 4-5" depending on the jaws' final size.
I will put mounting holes in the flange base to suit the machine T slots.
Not sure if I will make replaceable jaws or not?
Not shown are the threaded spindle and the anti rise plate. My mill table is 8" x 30", with a scope of 20" x 6" x 16" (X,Y,Z) travel
So, give me some feedback
Cheers Phil
tertiaryjim
H-M Platinum Supporter
Mar 3, 2014
629
I'm not able to mentally assemble all the components as drawn but got most of it.
One problem I've seen on older vises that saw hard and dirty use was wear in the guide slot for the traveling jaw
and the jaw itself. Though this would take many years to develop, I've often wondered if the jaw could be designed
with removable plates or slides so the slot could later be re-scraped and new, thicker, slides installed so the vise would
again be tight. Just something I've thought about when I've seen old iron that was abused and wasted.
Removable jaws would be a excellent feature and add versatility that you would later miss without them.
Another option would be a way to set the vice at an angle. This would let you cut ways that were to use gibbs and
who knows what else. Many machines have a hole in the table and the vise base has a pin to match so the vise can swivel.
Were you going to use a hardened key under the fixed jaw?
Looks like a nice project.
Jim
12bolts
Global Moderator
Apr 23, 2011
2,476
Well over 100+ views and only one reply. I must be doing something right!
Jim, I get you on the ability to tilt and swivel the vice, but that is going to add more mass and bulk to what will already be a fairly hefty lump of steel. So I think I will leave it as is and have a separate rotab fixture for that work. Good point about the jaws.
Cheers Phil
cjtoombs
May 10, 2012
820
If you look on Ebay, you can probably find a rotary base for a commercially available vise that you could use for the rotation. You might want to procure that first, so you can design the vise for attachment to it. I second the removable jaws comment. Being able to make V slot jaws or special jaws for holding difficult parts might come in very handy, also if you mess them up you can just replace them.
frugalguido
H-M Supporter - Gold Member
Jun 27, 2016
67
I will try and get some pictures and/or drawings from the parts books of the two EMCO-MAIER vices that I have, they are every similar to your design. I always thought that they would be easy to copy using stock like you have shown. One plus, that they have is the ability to adjust for wear on the moving jaw.
AdBlock Detected
I've Disabled AdBlock
