[4]
Vise Sizing
[3]
[10] Like what you see?
wvnitroman
Active Member
Apr 25, 2018
53
Finally decided on my machines, a PM 835S mill and a PM 1236T lathe. The mill has a 8"x35" table, what would be the "proper" size vise to order? What criteria do you consider to make your decision?
Thanks,
Kevin
mikey
Dec 20, 2012
5,306
Personally, I would go with a 5" vise. The main thing I look for is the distance between the center T-slot and the rear of the table. The clamping ears of the vise sit over the center slot and you don't want too much of the rear of the vise sticking out toward the column; this interferes with Y-travel. I also don't like having to peek around the handle end of the vise to see the indexing wheel for Y-travel; the less sticking out, the better.
I think a 6" vise fits fine on a 9" wide table. My mill has an 8" wide table and a 4" Kurt vise fits perfectly. I don't do really big work so the 4" is fine for me. Whichever vise you buy, buy a really good one.
Boswell
Hobby Machinist since 2010
H-M Platinum Supporter ($50)
Feb 27, 2014
761
If you need to work on something larger than the vice can comfortably hold, you can just remove the vice and attach the part directly to the table. Also Be sure to consider the weight. while I keep my 5" Kurt vice on the table most of time, I occasionally need to move it off. I can just manage this without help for the 5". If I had a bigger vice, I would need help.
ACHiPo
Feb 2, 2017
643
I have an 8” x 36” table and am quite happy with the Kurt DX6 I bought for it. The worst part is there can be interference with the big speed handle I bought from Grizzly, but I plan to make a shorter one.
[6]
[5] [7]
