- Mar 14, 2013
- 736
What I should have said there is a stepper motor AND drive. No, that would not work. Stepper motors are 2 phase motors that are driven by varying the current between the two windings. All of the real magic happens in the stepper drive. Now, having said that, you have to have something else to tell the stepper drive what to do. The input to the drive are Step and Direction.
The direction input is not a problem, a simple ON/OFF toggle switch will do.
The step input is a different matter. Each time the input is switched from OFF to ON, the motor will rotate one step, or 1.8 degrees. This is 200 steps per revolution. So you have to have something that will switch ON and OFF really fast, and do so accurately to be able to control the speed at a constant rate. There are stepper drivers with an oscillator built in that will allow speed control from a pot. There are also stepper speed controllers that connect to a stepper driver. Here is an example http://www.ebay.com/itm/Reversible-...stepping-/171122644460?_trksid=p2054897.l4275
For a complete lead screw drive system, you would need a stepper motor, a stepper drive, a stepper speed controller, and a power supply. Then also the mechanical hardware to connect the stepper motor to your lead screw.
Regarding the treadmill motor controller, you would need one rated for the motor horsepower.
OK, so Regarding the treadmill motor controller, you would need one rated for the motor horsepower, I do understand that........LOL
The other part clear as Mud..........................
No, LOL
I sort of do understand, and I understand it would not work with the window motor. (stepper motor drive)
There are a few free tread mills up in pittsburgh, but I am trying to find one around here.
