Wanting to power a lead screw
That one looks like it would work, and it seems they are a US manufacturer, located in Connecticut. At least you can call them if you have problem.
Yeah, a fellow by the name of iron man uses them.
Oh, I just saw you are a mod here.
I have not been here to much lately.
Well, I'll decide, I have to dig up a window motor too, I guess they use wiper motors too.
I will let you know, and probably post a video or some pictures at least.
Thanks again for your help.
This is what I used for my mill power feed. I also picked up a windshield wiper motor to turn it with. Power in, motor out. really simple. I put it in an enclosure with the pot sticking out.
Hi take a look at this it may help it's seen a lot of use now so I can recommend it.
and you have me here to help if required.
Power lead screw for 7x12.
Brian.
IDK, looks ,like posts are disappearing again.
Nice job on that, it is rare to see a wiper motor with only 2 wires.
What did you pay for your PWM unit?
Was it one of the ones from china?
price is right on it too, what are you using for a power supply?
To anyone, do you see any problem with this for a power supply?
From what l can see, it looks like it would be OK?
http://www.ebay.com/itm/SUPERNIGHT-...ing_Parts_and_Accessories&hash=item4adebca1da
It says for LED strip light, but the specks look OK don't they?
  • Input: AC 110V/220V ± 20%
  • Output: 12V DC 30A
  • The output direct voltage adjustable range: ±10%
  • The output voltage tolerance: ±1%
  • Nominal power: 360W
  • Protections: overload / over voltage / short circuit
I used this for a power supply. It may not be the best, but for what I have invested, if it craps out, oh well, I guess I'll replace it with something else. What you have in your last post might be a little better suited to the task.
