Well, no wonder why it broke!
pdentrem
Jan 28, 2011
3,480
Was trying out my diy tap and pow! The tap still needed more relief behind the cutting edge and the other handle finished the job with out breaking. I will make a new center section out of steel.
I have the same tap handle, didn't know it was even possible to break that thing, maybe if I use a tap with a bigger shank beyond its max capacity? :confused 3:, I should be more careful.
There are lots of holes at the one end! The tap was cutting brass, 1/2” 16 square thread. The first part was standard V thread to remove most of the metal before the square teeth started cutting in. Was a little tight at the beginning but cut easy. Handle must of been ready for retirement!
