welltronics x axis powerfeed
murraym
Feb 11, 2018
98
I have a Welltronics X axis powerfeed that does not work. Does anyone know of someone who can or is willing to attempt a repair?
The unit does not run at all. It did work at one time but sounded like there was a bunch of marbles in there. I took it apart and replaced the bearings and now it doesn't run.
I would really like to get this unit repaired as opposed to buying a new one.
Thank you,
Mike
I had a Wells power feed that was broke there was a place that had parts and repaired them, bui got rid of it as is on ebay
Replacing the bearings would not cause Does Not Run. Is it now an electrical problem or is a bearing jammed, or ???
Hi Mike- it does seem like you'll have to take it apart again and see if it's electrical or mechanical (jammed)
Mark
It is definitely an electrical issue. I have had it apart a few times now and can find nothing.
If it worked before the bearing replacement you'll have to check for loose connectors, broken wires, anything you might have bumped or moved
Can you post some pictures of the unit and the controller?
mark
