[4]
What did I get myself into??
[3]
[10] Like what you see?
Dgleavitt
Active Member
Oct 9, 2017
37
I picked up this “Surface Grinder” for 100 bucks. Supposed to be wired for 110 but get there and it is 220/440 3 phase. I got it anyway and hoping I can wire it for 220 and run a Teco VFD.
BUT...what is it??? It is a Royal Oak
D-S Grinder with a turntable head and dual wheel spindle. Can anyone tell me anything about it?
Dgleavitt
Active Member
Oct 9, 2017
37
Also forgot to mention that the hand wheels are also the “dials”. Scribed in thousandths.
benmychree
John York
Jun 7, 2013
2,847
Royal Oak is well known for form tool grinding equipment, but this one looks more like a simple tool & cutter grinder.
Dgleavitt
Active Member
Oct 9, 2017
37
Well that’s too bad, I was under the impression that tool and cutter grinders had a movable(angle) table, where this one is fixed. For 100 bucks I can’t complain too much, but I have to buy a teco fm50 which is another 115+shipping.
The grinder(220/440) is currently wired for 440v 3 phase. There is no wire diagram or numbers on the leads. Anyone happen to have a Lamb Electric 1/3 HP grinder head and know how to wire it to 220?
benmychree
John York
Jun 7, 2013
2,847
How many wires are there? There are basically two different wiring diagrams for 3 phase motors, star and delta connections.
Dgleavitt
Active Member
Oct 9, 2017
37
6 wires. The guy said it is wired for 440 now. It’s has three separate leads and then three wires joined together
benmychree
John York
Jun 7, 2013
2,847
If it is star wound, that is the connection for low volts (220)
line 1 1&7 together
line 2 2&8 together
line 3 3&9 together
4,5,&6 together
for 440 volts,
line 1 1
line 2 2
line 3 3
Together; 4&7, 5&8, 6&9
Take the tape off the connections and see if the numbers correspond with above; the connections for delta windings, the numbers are entirely different, but the high volts connection would be correct for your motor if it is indeed connected for high volts. For delta connection, low volts would be
line 1- 1,6,& 7 together
line 2- 2,4, & 8 together
line 3- 3,5,&9 together
The only way to confirm whether a star or delta connection is to separate all the wires and read out ohms between the windings, but I doubt that you will need to do that, likely it is a delta connected motor, if in fact the guy knew for sure that it was connected for high volts.
benmychree
John York
Jun 7, 2013
2,847
The info above came from a publication called "Engineering Pocket Handbook" it has lots of good info regarding electrical issues in a practical format, I have had my copy for about 48 years, and wouldn't be without it.
Dgleavitt
Active Member
Oct 9, 2017
37
No numbers only faint colors. The three separate wire(1,2,3 I guess) are white(ish) brown and black and the other three(connected together) are also white, brown and black.
benmychree
John York
Jun 7, 2013
2,847
Sometimes, the numbers are stamped on the terminals, I have never seen color coded wires. A motor shop could likely tell you the numbers by using an ohm meter.
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,176
If all else fails, take it to a local motor shop and ask for help. They will sort it out, test it, and make it the way you want it with a few minutes work. In my experience, motor shops are helpful and do not gouge customers. YMMV, but you WILL get an answer to your questions, and perhaps a quick reconnect it a few minutes for a few dollars.
brino
Jan 2, 2014
3,477
If the spindle doesn't wobble, and the lead-screws work, then you got a great deal.
Funny, nothing on lathes.co.uk or Vintage-Machinery for this.
I hope you keep posting your progress.
-brino
[6]
[5] [7]
