[4]
What does everyone think of this Mill
[3]
[10] Like what you see?
benmychree
John York
Jun 7, 2013
3,241
I have a Fray mill, but a simpler model than that one; yes, they are very versatile, mine has a 30 taper spindle, but some had B&S spindle tapers. They have larger way surfaces than Bridgeports, and are generally heavier, they have a planetary back gear in the driven pulley and have quite a broad speed range, they were made in Los Angeles, Ca.
MAKEITOUTOFWOOD
H-M Supporter - Silver Member
Dec 3, 2016
363
Should I be concerned with the #7 B&S taper? It only allows up to 1/2 diameter collets. The draw bar is 3/8. If this had the 30 tapper I would already have in my shop. I only have room for 1 mill. It looks like a very interesting machine.
ttabbal
Jun 12, 2017
880
I've seen a number of end mills with smaller shanks than the cutter size. You can always use a straight shank collet chuck held in the #7 collet. You can also get end mill holders that use set screws built to hold larger bits. I expect that machine has enough vertical clearance that the couple inches you lose to the chucks won't be a bother. I use an R8-ER40 adapter in my Bridgeport most of the time just because I find that the ER40s are more flexible for my uses.
I've also heard of people sending the spindle in to be reground, so you might be able to do that. It would likely be the most expensive option and you're without a machine till the job is done.
DougD
Mar 29, 2015
55
While a #30, 40 or R8 spindle would give you a lot more availability, the B&S #7 does not present a major problem or "major" limitation. A quick search of ebay shows a number of collets available a reasonable price. And as ttabbal stated above, using straight shanks gives you all the options you should need.
It looks like a good deal and price.
dd
MAKEITOUTOFWOOD
Dec 3, 2016
363
dd
Seller is away for the weekend. I have made arrangements with him to go look and buy Monday afternoon. I’m very excited. Have wanted a mill for a long time.
Thanks
Silverbullet
Gold
May 4, 2015
3,450
Buy it quick , very versatile mill, in some ways it's better then a Bridgeport . Collets can be found they may have them if you ask , must have been used there ?? There's one in my town the guy wants $2,300 been listed forever too. I tried trading since I'm on SS but nothing I had would do . Even a model 52 Winchester didn't get a thought.
MAKEITOUTOFWOOD
Dec 3, 2016
363
I plan on buying. I’m very excited. The more I read about it the more it sounds like a great mill. It looks to be in decent shape. There is a seller on eBay selling a b&s#7 to ER32 collet. I think I am going to go that rout. I will be able to run up to 3/4 diameter shank tools in that. I am more then good with that.
I will keep you all posted and post pics as as I have them to post. Cheers
Brento
Active Member
May 9, 2018
139
The er switch is the way to go i think i have a clausing 8520 and i went from a mt2 to a er20 i dont have a spot to hook up and make chips yet but im fine with working up to 1/2” tools. And i can always make a solid holder on the lathe
poplarhouse
New Member
Jul 9, 2018
27
$500? It's a no-brainer! Grab first and analyze later. Let us see some photos when you get it in place.
MAKEITOUTOFWOOD
Dec 3, 2016
363
I got the mill home. Still on the trailer. That’s where it’s staying till I can make some room. It is filthy. Needs some minor repairs and it would be nice to reprint the table. All in all I’m happy. It’s going to be a fun project. In the end I will have a nice knee mill with some mass. I’ll post some down and dirty pics tomorrow.
Cheers everyone
Cooter Brown
863 Bronze
Nov 23, 2017
609
Cheers everyone
Pictures or it didn't happen!
Creativechipper
Jul 9, 2018
256
Congats, sounds like a solid heavy winner!!
Very exciting times as you contemplate all the new possibilities.
Whats the 1st intended project using the mill?
Best of luck getting it fit in and moved.
ezduzit
Jul 19, 2013
476
I'm afraid that table damage is irreversible and will permanently take a lot of precision out of the original machine.
Brento
Active Member
May 9, 2018
139
Is that an actual step in the table or just a line from a vice sitting there for a while.
Eddyde
Bronze
Oct 13, 2014
1,480
The damage to the table looks like it could be ground out, might be pricy though.
[6]
[5] [7]
