[4]
What is it? Spool of 'Nil-Stain' wire.
[3]
[10] Like what you see?
middle.road
Actively Learning...
Apr 28, 2014
1,726
Digging around looking for something and this is laying in a box from 'who knows when....'
I don't think this is your regular run of the mill baling wire. . .
Cool spool, metal encased wood.
Date on it is May 1955.
Wilbur B. Driver Company.
Here's a link to a scanned PDF of a book that the company put out that a search returned...:
http://www.bunkerofdoom.com/lit/wbd/wbd_nopic_pub.pdf
Page 69 has some info on Nil-Stain, it's greek to me though.
P. Waller
H-M Platinum Supporter ($50)
Mar 10, 2018
913
I could be entirely wrong but that is likely insulated wire used in the manufacture of electromagnetic coil components, commonly known today as Magnet Wire. If the surface has a very high resistance it is likely insulated and was intended for such a purpose.
Also ni is the periodic chart symbol for nickle so it could also be a nickle alloy wire of unknown use, also the "NIL STAIN" trademark may imply that it leaves few or no stains on the finished product.
What does the text under the NIL STAIN logo say?
Found it, metal alloy wire manufacturer. http://snaccooperative.org/ark:/99166/w6gn6dng
Reddinr
Jan 5, 2014
138
A quick look at the publication says it is a stainless steel alloy wire. Hard to tell but it might be like 304 stainless as that is the only one they call out specifically in the table early on in the book.
Not so good for magnet coils because conductivity is not great. Cool find.
RJSakowski
Feb 1, 2015
3,757
In the reference that you linked, you will see the chemical and physical properties of Nilstain 310.
Ulma Doctor
Infinitely Curious
Feb 2, 2013
198
i use wire very similar to that in the food packaging industry.
Vacuum packaging machines use a Nickle/Chrome impulse sealing wire to seal packages under vacuum.
the circuit works like this,
you have a transformer, that for all intent and purpose,
has the Resistance wire coupled to the secondary circuit of the transformer, effectively short circuiting the transformer secondary output when power is applied to the primary circuit. usually the seal time (short circuit time) is less than 10 seconds
the short circuit heats the wire and the wire is held in indirect contact to the vacuum bag or tube
the heat fuses the bag halves together while the product is under vacuum.
the vacuum stays in the bag and the higher atmospheric pressure acts on the outside of the bag,
giving the vacuum pack.
cool find!
middle.road
Apr 28, 2014
1,726
What do we do with it now? I was thinking high-end hooks for Christmas ornaments... :grin:
Couldn't have been a spool of silver solder for brazing now could it? :grin big:
JimDawson
Global Moderator
Staff member
Feb 8, 2014
7,473
Looks to be lead coated 310 stainless spring wire, according to the documentation.
P. Waller
Mar 10, 2018
913
I am thinking ovens and other high temperature uses as noted above in the food industry.
1/8" diameter wire is large and you will find it difficult to form in a home shop.
It would make excellent large format paperclips I suspect (-:
middle.road
Apr 28, 2014
1,726
It's actually ribbon. I tried to twist it in the picture so that it would show.
Haven't mic it yet but I believe from that label it is .010".
Oh great - lead?!
whitmore
Active Member
Mar 3, 2017
369
The trademark Nilstain indicates Amax Metals corp 'ferrous alloys for electrical purposes'. Wilbur Driver was a marketer of
lots of different wire products, probably they did the final shaping of the wire. It's possible that this is a thermocouple
alloy, Wilbur Driver made a bunch of those... and 99% pure iron is a standard thermocouple wire which might
have borne this or other tradenames.
Best other idea I can come up with, is this is a weldable wire that can be made into resistors/heating elements (which, today, are usually
nichrome, i.e. nickel-chromium, not ferrous). Third-best idea, is that it's a weldable wire that is used to build
vacuum tubes' internal structures.
RJSakowski
Feb 1, 2015
3,757
From the documentation the lead coated spring wire was available as 302, 304, and 316. I would think that the 1/8" x .010" format would have limited uses as a spring.
310 has superior high temperature characteristics. I would guess that it would be used for heating elements in appliances like toasters or radient room heaters.
[6]
[5] [7]
