What is the HP of my motor?
yukon_rose
Jan 9, 2020
79
I have an old Repulsion-Induction motor with no nameplate. Well it actually has a nameplate but it is so destroyed that I might as well not have it.
However, I was able to read the name of the manufacturer: Century Electric Motor Co.
I've determined the voltage as 120VAC by experiment.
The motor needs new bearings but is otherwise just dirty. The brushes are in very good shape.
I want to know the approximate horse power of the motor. Can I measure the rotor (and possibly count the number of windings) to tell what the HP is?
Gary
Gary
If you have access to a clamp on a.c. ammeter, you can make a fairly good guess. Measure the current draw under load and the applied voltage.. Multiplying the two will give you power in watts. Dividing the watts by 750 will give you the input horsepower. Output horsepower will be approximately 80% of that number. A rough estimate but better than nothing.
The size of the motor shaft is often another clue. A 1/2" shaft is usually less than 1/2 horsepower. A 1-1/8" shaft is in the 3 HP range.
Craig
I have a couple of old Craftsman motors that are 1/2 HP with a 1/2 inch shaft. A 5/8 shaft would likely be a 3/4 HP. 3/4 inch shaft would be 1.0 HP. These are not hard and fast shaft sizes by any means. But for small motors would provide a reference point.
I haven't seen a repulsion/induction motor since the 70s when I was on a ship. An old ship~~~ The estimates above may not apply that well. The motor could well be a "special" application. But it does give a starting point.
Without a prony brake, setting the load would be difficult at best. Load it up until it runs warm, not hot after five minutes.
