- Sep 28, 2013
- 4,302
for that size starting hole, a 1/2" SCLCR boring bar. In my lathe I would most likely use a CCGT (sharp ground) insert as that's what works well on my small lathe. You would be fine with a CCMT (molded not as sharp, but more robust) insert.
I settled on CCxT inserts as I use the same inserts for facing, turning and boring. means I only have to buy one lot instead of several.
for your size lathe I'd guess the 32.51 or 43.51 (-09 or -12 in metric land) insert size would work well.
