[4]
What shim material for rf30/31
[3]
[10] Like what you see?
Investigator
Active Member
Jun 8, 2016
251
Likes
117
#1
Things are moving along nicely with the rebuild/refurbish of my mill drill. I am to the point that I need to check tram on the column. The question is what size and type of shim material do I need to get to go under the column? I know it will depend on how much needs to be shimmed, but what should I go buy to be ready?
benmychree
John York
Jun 7, 2013
2,756
Likes
1,996
#2
If I was to shim such a thing, I'd use brass, but if it is off tram, I'd rather hand scrape the column bottom instead.
Investigator
Active Member
Jun 8, 2016
251
Likes
117
#3
LOL, I'm barely competent to power the thing on, scrapping is outside of my abilities at the moment.
Bob Korves
H-M Platinum Supporter ($50)
Jul 2, 2014
6,060
Likes
6,390
#5
Look at this approach to the problem:
darkzero
Global Moderator
Staff member
Nov 27, 2012
3,043
Likes
1,920
#6
I used this to shim my square column mill drill. Just plain ol carbon steel. Mine was barely off so good enough for me. They also sell brass & stainless but an assortment pack of those ain't cheap.
I got mine from enco but I'm sure plenty of others carry it. Otherwise, like kd4gij mentioned, feeler gauge stock is inexpensive.
Bob Korves
Jul 2, 2014
6,060
Likes
6,390
#7
I have the same steel shim set package and use it fairly often. It is pretty reasonably priced for the size of the sheets and the number of sizes included. The sheets can be cut with a scissors, at least the thinner ones. The brass and stainless require a deeper wallet...
darkzero
Global Moderator
Staff member
Nov 27, 2012
3,043
Likes
1,920
#8
I'm sure brass would be ideal but these are light duty hobby mills. Would the material really matter much here?
I purchased this one cause it wasn't expensive & so I could use it for general purpose as well as shimming the mill. I last shimmed the mill years ago, hasn't changed since. Nice size sheets, for me personally may probably last me forever.
kdecelles
Active Member
Jan 12, 2017
53
Likes
15
#9
I've always used brass , but have that same steel sample pack too. I got mine from kbc tos
[6]
[5] [7]
