What should I make out of this?
Shootymacshootface
I make little metal out of big metal.
H-M Supporter - Silver Member
Mar 17, 2018
613
I believe this was for a wood shaper. The cutters are very hard. A file just skates over them. The center is 5/8" not sure of the threads. It has some weight to it and I'm sure it is well balanced.
I am thinking a fly cutter?
1555364778083124c33a160b216fe84de7849a6cf688b324b45ff0faa4a8a2fb7f5eebfe59460f50ff9f5b91e7da48...jpg
15553648104796011605a7d64bcc5717407fe6e99f1a32ae909f46ff863af1c1012c7e5f1d92a61a7caa29a4cd76dd...jpg
1555364823060b2926140d707c01269e63fc927d32a1cfde624ead285375d09b1937938eece1ad7572b55b028d1ace...jpg
pacifica
RGL
Jan 2, 2018
305
looks like a molding (fingernail) cutter for a wood shaper.
Bob Korves
H-M Platinum Supporter
Jul 2, 2014
7,326
It might cut aluminum and other softer metals, but it is really meant for wood, and using it on metal might abuse it.
Bob Korves
Jul 2, 2014
7,326
That tool has light cutters with slender and long cutting edges. That is fine for softer and easier cutting materials, and can leave a nice finish. If used on harder and tougher work, they can also flex quite a lot, making a worse finish and/or damaging or breaking the cutters. For harder and tougher materials, the cutters are usually made shorter and fatter, better supported for the tougher jobs they have to do.
Shootymacshootface
Mar 17, 2018
613
Thanks Bob, I was thinking about using a hss lathe tool or a broken drill bit vertically. I'm not sure if it would be worth the effort to make a shaft for the cutter.
cbellanca
Oct 28, 2018
96
It is a profile cutter for wood. It is designed to be used in a wood shaper. I would not attempt to cut any metal with it.
benmychree
John York
Jun 7, 2013
4,816
It is a wood cutting molding head suitable for a wood shaper, not metal cutting.
cjtoombs
May 10, 2012
856
You could regrind the blades on it to a more appropriate shape for metal cutting, but you would need to take care to ensure they were all cutting at the same distance from center. Bore the center and use it on a stub milling arbor. Don't know if it's worth that much effort, though, considering what you can get good used milling cutters for on Ebay.
MikeInOr
Jan 1, 2018
395
It looks like a drop leaf cove cutter for a wood shaper. The matching cutter would be a drop leaf bead cutter. Together they make the joint where a fold down table leaf attaches to the main part of the table.
Give it a try, be extra careful, make sure you are out of the line of fire if the cutter blows up. I wouldn't think the cutter would blow up... but I would setup my work expecting it to.
pontiac428
Mo-Max
Apr 23, 2018
1,341
I think you should use it to make a permanent cutter for your weed eater. Might need to up the compression and add a tuned pipe to it, but wouldn't it be fun?
Sent from my SM-T800 using Tapatalk
AdBlock Detected
I've Disabled AdBlock
