Way beyond big and fancy and shiny tooling, which take lots of time and usually some pricey steel, and I don't start working on, I find the biggest joy I get with my surface grinder is all the little stuff that needs cleaning up or making something fit properly. The mag chuck makes setups really fast for simple work, like making something thinner. Need a shim? Grab a flat washer is too thick, throw it on the chuck, and grind it until it fits. Only takes a few minutes, and it is in full control. Some things that you could work really hard to fit in a vise on a mill are simple when using a mag chuck on the grinder. I use mine often, and do not have a shaper or a T&C grinder. A surface grinder can do some cutting of tools, but it is not nearly as versatile as a T&C grinder, and often requires some thought to get some fussy sharpening job done. T
he answer is that you need all three, plus a place to put them, and a bunch of tooling, and...
