- Mar 12, 2021
- 63
So I have a decent feel of what I am looking for in milling machine, and still plan to end up with a RF45 style of Benchtop (if they can even be called that) mill
I tried to do some research, and really i have seen quite a lot of inconsistent information. I know there is a lot of how will you be using it and what kind of work and materials you will be using.
I do have a few generic questions that I am seeing or wondering what's the practical rule or advise. A ton of post I have seen people comment you wouldn't need more than a 4" vise while others advocate go for 5 or 6 or you will be wanting. I just want to understand some of the logic is all without hopefully going too deep down the rabbit hole as I know its well one of the more critical and reasonably expensive pieces of kit when starting out.
Is the bigger deal the weight? or the overhang (a lot of the pics I have seen there is quite a bit of overhang off the table) is the goal for the max of Jaw grip to be within the envelope or the table or more than half the vise? Even a lot of the 4 inch vises would overhang a table of 9.5 inch by at least 3-4 inches.
Is there negatives to using say a 6" vise to grip say something that is 3" long? in the middle of the jaws? On the edge of the jaws? Basically is there a reasoning that wider is not better.
rear jaw mount for lack of better term cast into the body vs keyed and bolted on? I know here quality of the devise is huge but curious as to the logic of what makes one better
I know the phrase of buy once cry once, but realistically from a hobbyist perspective is there a sweet spot in terms of "decent" I know obviously china 100 buck wonders are pretty dicey at best but the average hobby machinist do they really benefit from say a EDIT $600 Kurt (IDK what I was on before but still not a cheap vise by any means)
Personally I had been considering some of the Taiwan brands tike Tegara or Teco or some of the Palmgren lines of vises (really they probably are the same OEM) as a potential "reasonable" choice for a hobbies. Tegara has a shorter 6" CNC vise that seemed like a interesting proposition for a bench mill where your table is not quite so deep.
