[4]
What's wrong with my lathe?
[3]
[10] Like what you see?
harrzack
Harrzack
Mar 27, 2013
74
Greets! I have a LMS 3536/Sieg C4 lathe that for the most part is doing ok - especially after I REALLY learned to tighten things up GOOD.
Now I see an odd issue - when I do a power feed cut on the diameter, I'm getting a good finish. When I stop and hand-crank the carriage back out - there is a rather heavy cut being done again - seems a bit more than just spring. What might be causing the movement when hand moving the carriage as opposed to power feed?
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,668
That is spring. If everything is tight then hand cranking in either direction is the same as feeding under power. Play with the tool height, angle, and make sure the tool is sharp and not cutting behind the tip.
To test this theory, take a cut at a known depth, back the cross slide out, measure the part. My guess is that it will be larger than what you dialed in.
Mitch Alsup
Active Member
Nov 17, 2017
418
You need to get both hands coordinated so that you can take the carriage out of movement and back out the cross slide in a single movement.
JimDawson
Global Moderator
Staff member
Feb 8, 2014
7,668
Good advice for threading, but not applicable in this case.
David S
Nov 18, 2012
1,327
Also check the gibs for the cross slide. It sounds like the cross slide being driven in, is perhaps deflection toward the tailstock and then it relaxes toward the headstock as you manually retract it.
David
MrWhoopee
H-M Supporter - Silver Member
Jan 20, 2018
599
Back the tool out, return the carriage, crank the cross-slide back in to the same setting as the first pass. Take another pass with power feed. What happens?
higgite
Genral Manager - Proofreading Dept.
Aug 15, 2013
915
What material are you turning? What diameter? How much overhang/stick out from chuck? With or without tailstock center?
Tom
[6]
[5] [7]
