I need a cutoff tool for my Grizzly G0765 with the 4 way tool post. Not up to grinding my own yet.
I haven't found one on LMS or anywhere online that appears to fit 5/16.
Thanks
How tall is the opening of your 4way tool post relative to the centerline of your spindle?
Does my question make sense?
Need more coffee I guess. Maybe....
You'll probably have to grind something to work. I've done that a few times in the past. Just grind the sides for side clearance and width, and for a reasonable depth of about 3/8" back. Leave the top rake neutral at 0 degrees. Works great for parting off and grooving on small diameters. I'll post a picture of one when I get a chance.
