The pulley on my old mill is not in the greatest condition and I would like to replace it with a taper lock pulley for better fit. The original is pretty beat up and has a tendency to loosen up over time.
The pulley actually has 3 grooves, however I never use the smallest one (not shown on top)
This is used with a B34 V-Belt and a 2HP, 3-phase motor max RPM = 2200
The motor shaft is 0.875"
The diameters shown are what I have now, the replacement does not have to be exact, anything +/- 10% or so would be fine, as I control this with a VFD
If the 1.58" hub depth is a problem, I can shift the motor up closer to the pulley (somewhat) if need be.
Can anyone point me to a source for a suitable replacement?
Thanks,
Thanks,
