- Nov 5, 2016
- 1,418
Here's a link to the ones I used to build Jeroen Jonkman's brass Stirling 60. They match the dimensions in his drawings. He suggests open bearings so you can easily remove the grease, but you can from these as well.... they are shielded, not sealed, and letting them soak for several days in brake cleaner will dissolve the grease. They worked perfectly for my engine...
Ted
US Stock 10pcs MR104ZZ Miniature Bearings Ball Mini Bearing 4 x 10 x 4mm | eBay
Lubrication:Wide Temperature Range: - 20 C to 120 C. Vibration Level:V1- Above standard and less than V2.
www.ebay.com
Ted
